Check if document attachement is open
exits way how to check if customer open document in attachement ?
Thank you
Regards
Josef
Presumably not :confused: @michiel any way to make that work, would be cool :smile:
hmm, i need the feature :slight_smile:
You should not send an attachment, but instead put the file on your web site with a link to it in the email. You can then track clicks of that link.
Indeed, in the mean time, that is simple.
You can add a feature request https://www.phplist.org/development/#bugreport for the attachment thing.
