Hi
I would like to know if anyone would be able to help me with this problem I have. When I am sending an campaign, it sends messages later than I want it to due to the time zone. Does anyone know how to change the time zone to UK time?
Hi
The simplest way is to use the Timezone plugin.
Click the “Find plugins” link on the Manage Plugins page to go the page of available plugins.
How do I install this to the phplist?
Did you look at the page I referred to?
See https://github.com/bramley/phplist-plugin-timezone
You should be able to call your hosting provider and have the server time zone set to what it should be.
Could anyone tell me where I can find it on the phplist to install it? Can’t find it.
As @duncanc mentioned, you can find the plugin here:
