CaptchaPlugin disable
Before changing the server, CaptchaPlugin was working normally.
Now I can’t Enable.
It shows an error like this.
Dependency checkPlugin can not be enabled.
Failure on system requirement curl extension installed
@mexmet You need to enable the php curl module. If you don’t know how to do that then raise the issue with the system administrator.
