Hi guys, I’m happily running phplist 3.2.3 with no issues since my last post in april '16.
My provider gave the opportunity to have a certificate and move everything under https, so did I, forcing https adding these rows to .htaccess
@edorizzi You will need to try to debug the problem. From an email you can get the urls for user tracking and for image tracking, then access those directly from your browser. If you use developer tools in your browser then you can see what response phplist is sending.
thank you Duncan.
I just started a test campaign having just me as recipient.
can you pls. tell me where I can find those urls ?
I’m using Mac OSX Mail, I can see raw source or All headers: it seems to me that the only links I can see are:
list unsubscribe, list help, list subscribe in the headers, plus forward-to and unsubscribe links as per defined footer (all http; I’m working on the site as admin using https)
@duncanc so it seems that the server is responding properly when the url is pasted in a browser, but nothing happens when recipients open the mail … shall I double check something else ?
Thanks a lot for your kind support …
@duncanc Hi, I’m doing some tests with my provider.
what is happening is that the link that appears in message https://[mysite]/phplist/ut.php?u=7df1c379279dfe6ee3983ddcb774f6b9&m=167
does NOT work, but the same with http is fine (and redirected to https) http://[mysite]/phplist/ut.php?u=7df1c379279dfe6ee3983ddcb774f6b9&m=167
