First of all, congratulations for your great software.
I have a long list, I created a campaign and sent from the standard screen but only the first batch is sent.
The point is, initially as a test, I created a list with 3 subscribers, set batch size to send 1 by 1 and set the period to 5 minutes and all worked perfectly. Each 5 minutes a mail was sent until the end.
Now for the real case I have set to send in batches of 194 each hour. As said, the first batch is sent and nothing else. I have left the screen open as specified in the manual for hours and hours.
One question, Could it be due to cookie time expiration of the open screen?
The initial sending was yesterday evening. Today, in the morning, I have resent the campaign, and it detects that 194 were sent, so it has sent another 194 mails, but the screens shows the same as yesterday, so I guess nothing else will be sent.
The screen of today shows below messages, that are the same as yesterday, just changing the figure total mails to be sent (I am translating to english so words could not be exact)
Send queue
Processing queued campaigns
194 / xxxx
Started
Processing started
One campaign to process
Please keep this window open. phplist will process his queue till all messages have been sent. This will take a while.
The prcessing report will be sent by emial
Processing message 8
Searching users
Found: xxxx to process
Then in the frame down it repeats many times this paragraph:
It was sent a size smaller than the batch , so it will be reloaded immediately.
In the last 3,600 seconds more mails were sent (194) of what are allowed per batch (194).
State of script: 5
Ended nothing to do
Many thanks
