Bulk move subscribers
i am new user with Phplist.
while sending emails , i have certain amount of bounces .
i tried to move emails from one list to another but did not managed to do it.
i saw buld remove - where i can paste list of emails and either remove (if not already sent any email) or mark as blacklist and then remove blacklisted emails.
is there a way to move list emails from different listst to another list (paste list of emails and move)?
thanks in advance
@Zack_kovic The Subscribers Plugin provides a command to move subscribers from one list to another. You can copy/paste the list of email addresses. See plugin:subscribers [phpList Resources]
Hello Duncan,
thank you for your reply.
i tried to install Subscribers plugin - with github link from phplist interface and also manually.
in both cases i can see plugin in plugin in plugin list (manage plugin), but it does not add any additional functions in subscribers menu.
while link installation - it has no enable/disable button , only update button. i clicked several times but no changes.
while manual installation - it has nether enable/disable nor update button.
how can i fix this issue?
Thanks in advance
@Zack_kovic You need to enable the Common Plugin.
comon plugin is enabled .
here how it looks like (installed via interface):
@Zack_kovic There is a message stating that you need Common Plugin version 3.34.0. You need to update Common Plugin using a similar URL to that for Subscribers Plugin.
@duncanc yes, that was the issue.
Thank you very much
