Hi!
My bounced emails are not automatically being processed.
Is there there something wrong with my config settings?
They are being delivered to my listbounce email box that I specified, no problem.
I also have setup cron job successfully to send out 200 emails per hour, I don’t know if that has anything to do with things.
$message_envelope = ‘listbounces@xxxcom’;
$bounce_protocol = ‘pop’;
$bounce_mailbox_host = ‘xxx’;
$bounce_mailbox_user = ‘* removed ';
$bounce_mailbox_password = ’ removed *’;
$bounce_mailbox_port = “995/pop3/ssl/novalidate-cert”;
$bounce_mailbox_purge = 1;
$bounce_unsubscribe_threshold = 2;
define(‘MANUALLY_PROCESS_BOUNCES’, 0);
define(‘BLACKLIST_EMAIL_ON_BOUNCE’, 1);
Any ideas? Thanks!
