Bounce processing - Cannot create POP3 connection to {localhost:110/pop3/notls}INBOX: Connection failed to localhost,110: Connection refused
I just made a new installation of PHPlist and when I click on “Process Bounces” I get this message
“Cannot create POP3 connection to {localhost:110/pop3/notls}INBOX: Connection failed to localhost,110: Connection refused”
Settings in config.php seem to be ok as follows:
$message_envelope = ‘bounces@example.com’;
$bounce_protocol = ‘pop’;
$bounce_mailbox_host = ‘pop3.example.com’;
$bounce_mailbox_user = ‘bounces@example.com’;
$bounce_mailbox_password = ‘password’;
$bounce_mailbox_port = “995/pop3/ssl/novalidate-cert”;
$bounce_mailbox_purge = 1;
define(‘REPORT_DELETED_BOUNCES’, 0);
$bounce_mailbox_name = ‘INBOX’;
$bounce_mailbox_maximum = 100000;
$bounce_rules_batch_size = 500;
On my previous installation everything worked fine.
Any ideas?
