Feedback on the following chapter: https://www.phplist.org/manual/ch040_bounce-management.xhtml
After a few subsections all of the explanatory text is in bold.
thanks, reported https://mantis.phplist.org/view.php?id=17706
Hi, maybe I’m wrong but reading this chapter I think that there is a mistake here:
(account is disabled|This mailbox has been blocked due to inactivity|This account has been disabled|The email account that you tried to reach does not exist|This is a permanent error * local delivery failed)
Note that the * is a wildcard token that means there can be up to zero characters between “This is a permanent error “ and “ local delivery failed”.
I think that ‘This is a permanent error * local delivery failed’ should be ‘This is a permanent error .* local delivery failed’
Please let me know if I’m wrong.
Thanks in advance.
Sounds plausible, well spotted; thanks for sharing. You can edit the manual directly yourself – see https://www.phplist.org/bookstack. This will shortly replace the existing pages on https://www.phplist.org/manual/. You can create an account and edit any page
Hi, no problem.
I edited the page adding .* where necessary.
Hope that helps!
Awesome - thanks in behalf of all Manual readers!
I was looking at this chapter because I needed to check the settings in the config file and found that instead of hashes (#) the commenting out uses two slashes (//) This is just confusing especially when you are searching for hashes. I don’t know whether this is the case throughout the manual.
@StilmanDavis Good point, thanks! The characters were probably changed to reflect PHP coding standards. Yes the manual pages can be updated. You can edit the pages yourself by registering on bookstack.
Something for your next iteration of the manual.
Regards,
Stilman
The .pdf file titled sending and bounce rules phplist.pdf has serious formtting issues. The sample graphic images overlay the text such that it makes it impossible to read. See attached screenshots. As well, the page 29 fourth sentence down starts with word “Way” when they mean “We”.
Just FYI.
Hello!
I’ve browsed over documentation for quite a long time, but i never found an answer to this question and now, my little raspberry pi 3b+ is hanging while processing bounces.
Is there any way to limit how many bounces the script will handle each time?
Thanks!
In the phplist manual it states:
“The regular expression could be the exact sentence the MTA return message contained, in brackets.”
Yet the example provides parenthesis i.e,. () not brackets [].
Anyone know which it is? Does it make a difference?
