I tried to upgrade the autoresponder plugin clicking the “upgrade” under plugin management and it resulted in a deactivated autoresponder…
Now i dont know what i can do to get it back.
versjon2.3.1+20160304
Dependency checkPlugin can not be enabled.
Failure on system requirement Common plugin v3 installed
Any sugesstions?
You also need to upgrade the Common Plugin.
Thanks, that solved my problem.
@sttvsttv You will want to review the plugin’s documentation to understand changes since your old version https://resources.phplist.com/plugin/autoresponder_3.x
Duncanc I am getting the same Failure error. However I don’t have the Common Plugin installed.
Please advise.
You need to install the Common Plugin.
