Then I installed the last version of the autoresponder plugin (3.0.4+20180517) because I want to react to a new subscribing user sending him a message – it is my main goal when using PHPList.
But the autoresponder won’t send a single message. When a user subscribes and confirms, he never appears here in ‘subscribers ready’. The result of processing the queue always shows ‘Nothing to do’.
Did I miss something? Can you help me? Thanks.
@krold Also, the ready | not ready | already sent all being 0 suggests that the list for the autoresponder campaign are not the same as that being subscribed to.
Thanks for your answer @duncanc
Positive. I confirm. I checked all the topics you refer.
I just installed and configured the system. For now it is only under tests and I used several email accounts of my own to perform the subscriptions and test the autoresponder, that’s why you see ready | not ready | already being 0. I couldn’ t see autoresponder reacting to a single subscription!
Sending (simple) campaigns (without the use of the autoresponder) works ok.
Is there a log, more detailed, beyond systems log, where I can ‘see’ any information about the way PHPlist is managing subscriptions?
Thanks for your effort @duncanc
I’m sure Autoresponder is a great plugin, an indispensable one, and I used it before with another version of PHPList.
I will make a new blank installation and let you know if I succeeded.
What about a more complete log of events? Any form to understand and track what is going on on PHPList? Is there any?
