Not sure if I’m doing this right…but I created attributes mapped to my CSV file, then I try to import, it says there’s an error before even starting, then import works anyways, but only email field gets imported…!
The error is this:
Database error 1064 while doing query You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'fname","title","industrytype","stateprovince","city""' at line 1
