I recently installed the Advanced Statistics plugin.
When I click the link to view them I get the following text showing up:
Argument 1 passed to phpList\plugin\Common\DBResultIterator::__construct() must be an instance of mysqli_result, resource given, called in /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/Common/DB.php on line 79 and defined
#0 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/Common/DBResultIterator.php(29): phpList\plugin\Common\Exception::errorHandler(4096, 'Argument 1 pass...', '/home3/hostname/p...', 29, Array)
#1 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/Common/DB.php(79): phpList\plugin\Common\DBResultIterator->__construct(Resource id #396)
#2 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/Common/DAO/Attribute.php(64): phpList\plugin\Common\DB->queryAll('SELECT id, \n ...')
#3 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/Common/DAO/Attribute.php(39): phpList\plugin\Common\DAO\Attribute->attributes()
#4 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/MessageStatisticsPlugin/dic.php(102): phpList\plugin\Common\DAO\Attribute->attributesById()
#5 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/CommonPlugin/vendor/mouf/picotainer/src/Picotainer.php(61): MessageStatisticsPlugin_ControllerFactory->{closure}(Object(Mouf\Picotainer\Picotainer))
#6 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/MessageStatisticsPlugin/dic.php(90): Mouf\Picotainer\Picotainer->get('attributesById')
#7 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/CommonPlugin/vendor/mouf/picotainer/src/Picotainer.php(61): MessageStatisticsPlugin_ControllerFactory->{closure}(Object(Mouf\Picotainer\Picotainer))
#8 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/MessageStatisticsPlugin/dic.php(68): Mouf\Picotainer\Picotainer->get('MessageStatisti...')
#9 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/CommonPlugin/vendor/mouf/picotainer/src/Picotainer.php(61): MessageStatisticsPlugin_ControllerFactory->{closure}(Object(Mouf\Picotainer\Picotainer))
#10 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/MessageStatisticsPlugin/ControllerFactory.php(48): Mouf\Picotainer\Picotainer->get('MessageStatisti...')
#11 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/Common/Main.php(41): MessageStatisticsPlugin_ControllerFactory->createController('MessageStatisti...', Array)
#12 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/plugins/MessageStatisticsPlugin/main.php(35): phpList\plugin\Common\Main::run(Object(MessageStatisticsPlugin_ControllerFactory))
#13 /home3/hostname/public_html/mywebsite.com/mailinglist/admin/index.php(508): include('/home3/hostname/p...')
#14 {main}
I checked the GitHub page and reinstalled manually but cannot seem to figure this one out. Any ideas?
