I have my installation in http://mydomain.com/list I have set $pageroot and $adminpages in the config file. Still many functions revert me back to http://mydomain.com/admin which causes s 404
Hi, can you copy and paste the code of your config, EXCLUDING passwords, using the code tag < / >
Also, can you explain what you are trying to achieve in more detail, neither of URL you describe fit the norm in phpList.
Anna
What version of phpList are you using please? $adminpages are no longer used in Version3.
From what you’ve said above, $pageroot should be set to "/list"
If you are running V3, please confirm that you are using config.php file and not extended_config.php
Using 3.0.12
General settings for language and database
$language_module = "english.inc";
$database_host = "**********************";
$database_name = "**********************";
$database_user = "anchoragemarine";
$database_password = '**********************';
$installation_name = 'PHPlist';
$table_prefix = "phplist_";
$usertable_prefix = "phplist_";
$pageroot = '/list';
$adminpages = '/list/admin';
Settings for handling bounces
$bounce_protocol = 'pop';
define ("MANUALLY_PROCESS_BOUNCES",1);
$bounce_mailbox_host = '**********************';
$bounce_mailbox_user = 'popuser';
$bounce_mailbox_password = 'password';
$bounce_mailbox_port = "110/pop3/notls";
$bounce_mailbox = '/var/spool/mail/listbounces';
$bounce_mailbox_purge = 1;
Security related settings
$require_login = 1;
define("MAXLIST",1);
$commandline_users = array("admin");
define("ASKFORPASSWORD",0);
define("UNSUBSCRIBE_REQUIRES_PASSWORD",0);
define("UNSUBSCRIBE_JUMPOFF",0);
$blacklist_gracetime = 5;
define("CHECK_SESSIONIP",1);
define("ENCRYPTPASSWORD",0);
$check_for_host = 0;
Debugging and informational
define ("TEST",0);
define ("VERBOSE",0);
define ("WARN_ABOUT_PHP_SETTINGS",1);
define ("MANUALLY_PROCESS_QUEUE",1);
define('SEND_QUEUE_PROCESSING_REPORT',true);
define("WORKAROUND_OUTLOOK_BUG",0);
$userhistory_systeminfo = array(
'HTTP_USER_AGENT',
'HTTP_REFERER',
'REMOTE_ADDR'
define('USE_SPAM_BLOCK',1);
define('NOTIFY_SPAM',1);
Feedback to developers
define ("REGISTER",1);
define("EMAILTEXTCREDITS",0);
define("PAGETEXTCREDITS",0);
define ("NOSTATSCOLLECTION",0);
Miscellaneous
define ("NUMCRITERIAS",2);
define("ALLOW_NON_LIST_SUBSCRIBE",0);
define("MAILQUEUE_BATCH_PERIOD",100);
define('MAILQUEUE_THROTTLE',0);
define('DATE_START_YEAR',0);
define('DATE_END_YEAR',0);
define('EMPTY_VALUE_PREFIX','--');
define('USE_ADMIN_DETAILS_FOR_MESSAGES',1);
define('SEND_ONE_TESTMAIL',0);
Experimental Features
define("USE_LIST_EXCLUDE",0);
define("STACKED_ATTRIBUTE_SELECTION",0);
define('REMOTE_URL_REFETCH_TIMEOUT',3600);
define('MAILQUEUE_AUTOTHROTTLE',0);
define('CLICKTRACK',0);
define('CLICKTRACK_SHOWDETAIL',0);
define('USE_DOMAIN_THROTTLE',0);
define('DOMAIN_BATCH_SIZE',1);
define('DOMAIN_BATCH_PERIOD',120);
define('DOMAIN_AUTO_THROTTLE',0);
define('LANGUAGE_SWITCH',1);
define('USE_ADVANCED_BOUNCEHANDLING',0);
Security
define('CHECK_REFERRER',false);
$allowed_referrers = array();
Advanced Features, HTML editor, RSS, Attachments, Plugins. PDF creation
define("HTMLEMAIL_ENCODING","quoted-printable");
define("TEXTEMAIL_ENCODING",'7bit');
define("ENABLE_RSS",0);
define("MANUALLY_PROCESS_RSS",1);
define("USEFCK",0);
define("FCKIMAGES_DIR","uploadimages");
define("USETINYMCEMESG", 0);
define("USETINYMCETEMPL", 0);
define("TINYMCEPATH", "plugins/tiny_mce/tiny_mce.js");
define("TINYMCELANG", "en");
define("TINYMCETHEME", "advanced");
define("TINYMCEOPTS", "");
define("USE_MANUAL_TEXT_PART",0);
define("ALLOW_ATTACHMENTS",0);
define("NUMATTACHMENTS",1);
define("FILESYSTEM_ATTACHMENTS",0);
define("MIMETYPES_FILE","/etc/mime.types");
define("DEFAULT_MIMETYPE","application/octet-stream");
define("PLUGIN_ROOTDIR","/home/me/phplistplugins");
$attachment_repository = '/tmp';
$export_mimetype = 'application/csv';
define("EXPORT_EXCEL",0);
define("USE_REPETITION",0);
define("USE_PREPARE",0);
define("KEEPFORWARDERATTRIBUTES",0);
define("FORWARD_EMAIL_COUNT",1);
define("FORWARD_PERSONAL_NOTE_SIZE",0);
define("FORWARD_ALTERNATIVE_CONTENT",0);
define("PHPMAILER",1);
define("PHPMAILERHOST",'');
$tmpdir = '/tmp';
$database_module = "mysqli.inc";
Are you still using the Version 2 config.php file? As I say, $adminpages is no longer used in Version 3 which I see you are using, but if you are still using version 2 config file there’s a lot missing which needs to be in the version 3 config file.
