I installed PHP list with no major issues other than when you go to lists/admin and try to login, it just loops and doesn’t take you to the login area.
If you view the source, it looks like only the header info is being display as the last listed in Content Goes here and there the re are not footer elements.
Strangely enough, going to lists/ actually allows you to submit your email and join a list even thought I’ve not been able to get into admin and set one up.
IT’S ALL BLANK! Okay, remember the message on the Hitch Hikers’ Guide to the Galaxy? Don’t Panic!
This is usually down to an error creeping in when you altered the config.php file. This can be as minor as deleting a quote or semicolon when you set the database parameters. Go back in to config.php file, text editor, don’t forget and look at each setting you changed.
Each of the lines you altered MUST end with a semi-colon ( also if you accidentally deleted a quote when setting the values for the database or lists paths, that can cause a blank page.
This is a known problem that was known about and fixed in March but hasn’t been released, see https://mantis.phplist.org/view.php?id=17560#c55984
I can’t guess how many people have been affected by the problem, which could have been avoided simply by releasing the fix.
Just to update, I uninstalled and then installed version 3.0.6 and it works great. I’m now seeing a bunch of stuff that was missing from the newer versions that I did not know was there.
When ever that .mb_ extension was introduced, it seems to have cause many issues for certain servers.
What monthly payment version? phpList is a free download if you host it yourself. The only monthly costs should be your site hosting charges, be it phpList hosting or your own.
To be absolutely clear, the delay between releases is because we have been overhauling the development process, very much for the benefit of the community. We are introducing release candidates, starter bugs and code reviews etc.
I have spent much of my time over the last month or so negotiating improvements to how we collaborate, and we are now coming to the end of that process. I think we have done well, and should be having much better development in the future. I appreciate that it has been less than ideal, but we have a lot to gain too I hope?
