A release candidate is available for testing for the upcoming version 3.6.4! This RC introduces improvements and fixes.
You can get a copy of the RC version from GitHub or SourceForge. On SourceForge you will notice that files are named “phplist-3.6.4-RC3” and that is because the build process failed initially.
Changes have been made to address the following issues:
New feature:
When marking a message as sent, set the “Sent” field to the current time. Have a look at Pull Request #775
Improvements:
- Handling PHP 8 better and considering an installer as a “superuser”. Have a look at Pull Request #777
- Reintroduce composer.json after failure in including the file during build process - problem caused when build and release process changed during the last release. See Pull Request #779.
Guidelines
Upgrading
Upgrade from releases older than phpList 3.3.7-RC1 following the usual upgrade process. You can get a copy of the RC version on SourceForge as well.
Activating the REST API
If you haven’t checked the REST API yet, you can see the dedicated chapter in the manual to help you get started with it: API and Integrations.
Reporting issues
Report any issues you find with phpList3 RC to the phpList3 GitHub repository, selecting “release candidate” in the Labels’ dropdown menu.
Happy testing!
Mariana
