Hi everyone,
A Release Candidate for the upcoming phpList 3.6.15 is now available for testing.
This release includes security enhancements.
You can get a copy of the RC version from GitHub or SourceForge.
Changes to look for
- Added support for indicating and getting feedback for test campaigns. With this PR, a “Test” subject indicator will be appended to test campaigns. See Pull Request #1031.
- Allow subscribers to be filtered by confirmed and/or blacklisted. See #Pull Request 1030.
- Added “Bounces” subscriber status indicator and allow admin to confirm a subscriber right from the Bounces tab. See Pull Request #1029.
- Added “bouncemgt” to allow processing only existing bounces and a related new rule action. See Pull Request #1028.
- Use the utf8mb4 charset for client-server exchanges. Using utf8mb4 will allow a wider range of characters, including emoji characters, to be sent. If once-off database table changes are made, subject lines can include emoji characters. This change is backward compatible; it has no effect when supplementary characters are not used. See Pull Request #1001.
- Allow Ajax page links to have a title, defaulting to the link description. The title is shown when hovering over the link. See Pull Request #1002.
- Add a notification by email when an admin logs in from a new IP address. See Pull Request #1027.
- Escape the single quote in the error message returned by allowMessageToBeQueued(). See Pull Request #1003.
- Update the CI to remove old PHP versions and add 8.3. See Pull Request #1004.
- Restore the ability to create other superusers. See Pull Request #1014.
- Define timestamp columns explicitly. See Pull Request #1019.
- Remove redundant upgrade steps. See Pull Request #1020.
- avoid the admin being kicked out after the upgrade. See Pull Request #1033.
- Update the Common and Segment plugins. See Pull Request #1024.
- Updated translations in French. See Pull Request #1032.
- Use the list order, even when grouping by category. See Pull Request #1025.
- Updated the UUID class to the latest upstream. See Pull Request #990.
- Additional PHP 8 fixes. See Pull Request #1026.
- Removed obsolete references for Mantis, the old bug tracker. See Pull Request #994.
Activating the REST API
If you haven’t checked the REST API yet, you can see the dedicated chapter in the manual to help you get started with it: API and Integrations 4 3.
Reporting issues
Report any issues you find with phpList3 RC to the phpList3 GitHub repository , selecting “release candidate” in the Labels’ dropdown menu.
Happy testing!
