3.6.15 Categories in Lists tab are not grouped
in phplist 3.6.15 while creating a new campaign lists categories are not selectable like a previous version with a dropdown menù. I see all lists in a single page.
In a previous version list could be filtered like it happens navigating in the Users lists menu.
How can i solve this ?
Thanks in advance.
Dino
@Pex It is probably the same problem as raised a few months ago Sort Categories on Subscribe Page - #2 by duncanc
You need to re-order the lists so that the lists in each category are numbered together.
I’ve tried but they are sorted but not grouped like before.
In the Users-> Lists menu
This scrolldown menu is not grouped if you send a message.
We have a lot of categories and a lot of lists.
And if you choose the category you are not positioned in the top of that category but it does not scroll. If you open the list right clicking to another page it works.
But the result is still not grouped.
@Pex I don’t quite understand what you are referring to. Is it the Lists page or the Lists tab when composing a campaign? The Lists tab looks like this for me, with each category displayed as a tab
In the previous version it was like i posted, a dropdown menu, in this one is not even tabbed.
I’ve trried with several browser with the same result.
@Pex It might be a problem with the code for the theme that you are using, Dressprow. That theme is no longer supported, for several year now. You should use the bootlist theme instead by choosing that on the Settings page.
Thank you, reinstalled it because the tarball i’ve deployed didn’t contain the theme.
Using another one it worked out.
