Hi everyone,
A Release Candidate for the upcoming phpList 3.6.14 is now available for testing.
This is a security release.
You can get a copy of the RC version from GitHub or SourceForge .
Changes to look for
- Disallow non-superusers to elevate admin admin privileges. See Pull Request #986.
- Use config.php in the default location when using the command line. See Pull Request #977.
- Increase the size of the
modifiedbyfield to conform with the size increase of theloginname. See Pull Request #976. - Correct the display of a select list for a boolean config item. See Pull Request #975.
- Call the messageReQueued() method when a campaign is resent to additional lists. See Pull Requests #974.
- Allow plugins to be installed from GitLab as well as GitHub. See Pull Request #973.
- Remove outdated settings and code that are no longer needed. See Pull Request #972.
- Update the composer.lock file to use the latest CKEditor, Common, and Updater plugins. See Pull Request #971.
- Update to UUID parsing. See Pull Request 970.
- When using domain throttling, apply delay only when email was sent. See Pull Request #968.
- Replace constants in the bounce handling code by config.php settings. See Pull Request #963.
- Remove outdated code that is no longer needed from languages.php. See Pull Request #962.
- Protect the invocation of the function output(). See Pull Request #959.
- Changes to increase compatibility with PHP 8. See Pull Request #940.
Activating the REST API
If you haven’t checked the REST API yet, you can see the dedicated chapter in the manual to help you get started with it: API and Integrations 4 .
Reporting issues
Report any issues you find with phpList3 RC to the phpList3 GitHub repository , selecting “release candidate” in the Labels’ dropdown menu.
Happy testing!
