Hi everyone,
A Release Candidate for the upcoming phpList 3.5.13 is now available for testing.
You can get a copy of the RC version from GitHub or SourceForge .
Changes to look for
Allow a plugin to update phpList. Identify whether a plugin is able to update the phpList code, and link to that pluginsās update page when a new release is available. See Pull Request #946.
On Pull Request #926, we used the
<wbr>element immediately after a character where we want to allow wrapping. Copying/pasting an email address includes only the characters of the email address, not the<wbr>element. Specifically:
- changes the shortenTextDisplay() function to handle only text fields
- adds a similar shortenEmailDisplay() function which uses the
<wbr>element - adds a similar shortenUrlDisplay() function which uses the
<wbr>element - replaces the uses of shortenTextDisplay() for email or URL fields by the new functions
- Make the results of the timer class use period as the decimal point to avoid failing calculations. See Pull Request #931.
- Set DEFAULT_MESSAGE to 8 days so that repeated campaigns donāt expire. See Pull Request #932.
- Allow a gap between async requests. Check out the Resources Wiki for additional documentation. See Pull Request #937.
- Update the Common, CKEditor, and Segment plugins. See Pull Request #951.
- Use the content of the body element when including a message in a template. See Pull Request #938.
- Pull Request #935 includes several commits that tidy-up the output of processqueue. Specifically:
- Fix the processQueueOutput() function in several places
- Replace $GLOBALS[āI18Nā]->get() by s()
- Replace a few uses of a call to sprintf() wrapping s()
- Minor changes to avoid warning on PHP 8.2. See Pull Request #930.
- Remove unused files. See Pull Request #936.
Activating the REST API
If you havenāt checked the REST API yet, you can see the dedicated chapter in the manual to help you get started with it: API and Integrations 4 .
Reporting issues
Report any issues you find with phpList3 RC to the phpList3 GitHub repository, selecting ārelease candidateā in the Labelsā dropdown menu.
Happy testing!
Mariana
