3.6.1 Release Candidate is ready for testing
A Release Candidate for the upcoming phpList 3.6.1 is now available for testing. This release includes security enhancements and fixes.
Changes to look for
New features
  • Log event for fetching URL success only when verbose is now enabled. The function fetchUrl() adds to the event log in several places. In all but one case that is when VERBOSE is enabled. Thanks to @duncanc or the implementation. Have a look at the Pull Request.
  • Remove leading HTTPS as well as HTTP when shortening a URL. Previously, when a URL was shortened for display, such as to show link clicks, a leading “http://” was removed but not a leading “https://”. Thank @duncanc for the implementation. Have a look at the Pull Request.
Functionality Enhancements
  • A JavaScript event has been disabled to enhance the security of the application.
  • Small fixes have been added to ensure the application works fine with PHP 8.
Fixes
  • Documentation for UNSUBSCRIBE_JUMPOFF has been updated to be optimum.
  • Change results display to information so that the content stays on the page. See Pull Request.
Guidelines
Upgrading
Upgrade from releases older than phpList 3.3.7-RC1 following the usual upgrade process. You can get a copy of the RC version on SourceForge as well.
Activating the REST API
If you haven’t checked the REST API yet, you can see the dedicated chapter in the manual to help you get started with it: API and Integrations.
Reporting issues
Report any issues you find with phpList3 to the phpList Bugtracker, selecting “3.6.1-RC1” as the Product Version.
Happy testing!
Mariana
