3.5.2 Release Candidate ready for testing
A Release Candidate for upcoming phpList 3.5.2 is now available for testing.
This release includes fixes, usability & functional improvements
Changes to look for
  • Link the number of bounces on the List of Campaigns page with the ā€œmsgbouncesā€ page which shows bounces only for that campaign – thanks to @duncanc, see the pull request
  • Add the bounce Id as a link to the actual bounce in the ā€œMessage bouncesā€ page and remove duplicated links to the ā€œSubscribers’ Profileā€ – thanks to @duncanc, see the pull request
  • Changes to import1 page to avoid spurious changes reported when the file contains an existing subscriber followed by a new subscriber – thanks to @duncanc, see the pull request and the mantis issue for the detailed description of the problem.
  • Make the total clicks value consistent between the Campaign click statistics summary page and the detailed page for a specific campaign – thanks to @danwaterloo for reporting the issue and @duncanc for providing the fix. See the pull request
  • To simplify testing later versions of PHPMailer allow PHPMAILER_PATH to specify a version different to PHPMailer 6 – thanks to @duncanc, see the pull request
  • Avoid changing URLs that already have a scheme, as initially reported here by @dwo – thanks to @duncanc for providing the fix, see the pull request
Other
Updated dependencies on phpList 4 core module – thanks to @oliverklee
Download the Release Candidate here (see also ā€˜Upgrading’).
Guidelines
Upgrading
Upgrade from releases older than phpList 3.3.7-RC1 following the usual upgrade process
Activating the REST API
Reporting issues
This RC is available for testing until the final release expected on August 11th. If a new RC will be necessary based on the feedback shared, an announcement will be posted in advance.
Report any issues you find with phpList3 to the phpList Bugtracker, selecting ā€œ3.5.2-RC1ā€ as the Product Version.
Happy testing!
