3.4.8 Release Candidate Ready for testing
A Release Candidate for upcoming phpList 3.4.8 is now available for testing.
Changes to test
On this release candidate support for phpMailer 6 is added – thanks to @duncanc.
Among other changes, PHPMailer 6 now requires php 5.5+
and it uses namespaces, which makes it backwards-incompatible.
Changes implemented by @duncan to the PHPlistMailer class make it possible to use either PHPMailer version 5 or version 6 depending on a config setting (default values is set to “false”).*
To use PHPMailer 6 add the line below on your config.php. If you want to switch back to using PHPMailer 5 just remove the line.
define('USE_PHPMAILER6', true);
If you want to check the changes in more details please refer to the pull request and the mantis issue.
For more information on changes introduced on PHPMailer you can check their changelog here.
Download the release candidate here (see also Upgrading)
Guidelines
Upgrading
Activating the REST API
Reporting issues
This RC is available for testing until the final release expected on November 11th. If a new RC will be necessary based on the feedback shared, an announcement will be posted in advance.
Report any issues you find with phpList3 to the phpList Bugtracker, selecting “3.4.8-RC1” as the Product Version.
Happy testing!
Edit: Please note the post was edited to clarify how you can enable PHPMailer 6.
Thanks,
Suela.
