A Release Candidate for upcoming phpList 3.4.7 is now available for testing.
Changes to test
- Switch to Parsing CSV files by CSV standard - rfc4180
Thanks to @vaceklu and @duncanc for initiating and implementing the changes.
More details about this on the Mantis issue and the pull request
Correct the display of select list configuration item that sometimes displays the option value instead of the option text β thanks to @duncanc, see the pull request
Fix missing β=β in some html elements β thanks to @duncan, see the pull request
To make it easy to view the archive of community news, the widget title is now linked to the news page.
Download the Release Candidate here (see also βUpgradingβ).
Guidelines
Upgrading
Activating the REST API
If you havenβt checked the REST API yet, you can see the dedicated chapter in the manual to help you get started with it: API and Integrations
Reporting issues
This RC is available for testing until the final release expected on October 11th. If a new RC will be necessary based on the feedback shared, an announcement will be posted in advance.
Report any issues you find with phpList3 to the phpList Bugtracker, selecting β3.4.7-RC1β as the Product Version.
Happy testing!
