A Release Candidate for upcoming phpList 3.4.6 is now available for testing.
This is a small but significant release as the Dressprow theme is no longer included by default.
The Dressprow code repository will continue to be available on GitHub for those who wish to manually install and develop it.
Changes to test
- Avoid paging past the final page of results, and display only the remaining items on the last page when displaying a set of results using – thanks to @duncanc, see the pull request
- Add uid of the subscriber to the attachment URLs included in messages sent as text – see the pull request
- Move the “Help” icon from the ‘List of templates’ page to the ‘Add or Edit a template’ page, where the information is more relevant
Download the Release Candidate here (see also ‘Upgrading’).
Guidelines
Upgrading
Activating the REST API
Reporting issues
This RC is available for testing until the final release expected on September 11th. If a new RC will be necessary based on the feedback shared, an announcement will be posted in advance.
Report any issues you find with phpList3 to the phpList Bugtracker, selecting “3.4.6-RC1” as the Product Version.
Happy testing!
