A Release Candidate for upcoming phpList 3.4.4 is now available for testing.
This release includes several fixes, usability & functional improvements plus one new feature.
Changes to look for
- Added option to search through your lists. “Search lists” will currently search within the category of lists you have displayed if categories are set up – thanks to @xheni , see the pull request
- Fixed problem with the language menu noted in the last release notes
- Fixed plugin update error due to PHP 7.3 bug – thanks to @duncanc, see the pull request
- Fixed ‘Select All’ checkbox not working when selecting lists with list categories set – thanks to @petersphilo for reporting the issue and providing the solution. Check the mantis issue
Full list of changes here.
Download the Release Candidate here (see also ‘Upgrading’).
Guidelines
Upgrading
Activating the REST API
Reporting issues
This RC is available for testing until the final release expected on July 11th. If a new RC will be necessary based on the feedback shared, an announcement will be posted in advance.
Report any issues you find with phpList3 to the phpList Bugtracker, selecting “3.4.4-RC1” as the Product Version.
Happy testing!
