3.4.1 Release Candidate Ready for testing
A Release Candidate is now available for testing. This release introduces changes to the REST API and the Automatic Updater.
REST API
This update makes the API calls accessible via shorter URLs, e.g:
Base URL: http://example.com/lists/api/v2/
Authentication: http://example.com/lists/api/v2/sessions
Please make sure to have htaccess and mod_rewrite enabled.
Automatic Updater
The Automatic Updater now handles your plugins folder more conveniently, so any plugins outside the default suite that you are using will no longer be removed (Please consider that the old version of the updater will pull this update so, this one will remove them.)
Information about paid community support and phplist.com hosting is now shown during the Automatic Update process.
Other changes to look for:
  • Added check for the config table prefix so the Updater can be used in installation that have a different table prefix from the standard one (Example: Softaculous)
  • Use the correct variable for the custom forward footer when forwarding to avoid empty footer on the recepient – thanks to @Duncanc
  • Added check for modules required by phpList and display the PHP module that is missing to avoid white page display
Full list of changes here
Download the Release Candidate here if you are running a version older than 3.3.7-RC1.
Guidelines
Activating the REST API
All these and more are added on a dedicated chapter on the manual, API and Integrations
Upgrading
Upgrade from releases older that phpList 3.3.7-RC1following the usual upgrade process
Use the Automatic Updater if you are running phpList 3.3.7 or latter.
Use your phpList as normal, and report any new problems you find.
Reporting issues
This RC is available for testing until Wednesday, April 10 as a new RC will be released later on the week.
Report any issues you find with phpList3 to the phpList Bugtracker, selecting β€œ3.4.1-RC1” as the Product Version.
Happy testing!
Hi everyone,
A new RC for version 3.4.1 is available for testing . Available for manual download here.
This RC includes a fix for the blank public pages problem introduced with installations upgraded to 3.4.0 so, if your account was affected please test and let us know if it’s working properly on your system.
If you find any issues on this RC please create a mantis ticket with the version number set to 3.4.1-RC2 so that we can keep trace of the last version that issue was present at.
Thanks for your time and happy testing!
