I’ll be using phpList for newsletters, which I know how to setup and use. I installed the program from cPanel but receive daily emails like below. I’ve tested sending emails and things appear fine so if someone can explain to me the meaning of this message, and how to fix, I’d appreciate it. I did contact Zend but received no response.
SUBJECT: Cron softm3@kuma php -q /home/softm3/public_html/phplist/admin/index.php -pprocessqueue -c/home/softm3/public_html/phplist/config/config.php >/dev/null
MESSAGE:
Zend OPcache requires Zend Engine API version 220121212.
The Zend Engine API version 220131226 which is installed, is newer.
Contact Zend Technologies at http://www.zend.com/ for a later version of Zend OPcache.
