Upgrading manually: manual chapter feedback and discussion
Feedback on the following chapter: https://www.phplist.org/manual/books/phplist-manual/page/upgrading-a-manual-installation
The page on automatic updating is broken.
Is it possible to perform the automatic updater and database upgrade functions from the CLI?
@simba You’re right, thanks for reporting. Not sure why.
DB upgrade should be possible via CLI. See: https://resources.phplist.com/system/commandline
The Automatic Updater is not yet accessible via CLI.
FYI @xheni @Suela
@anna Can the link https://www.phplist.org/manual/ch031_upgrading.xhtml be redirected to the new page ( https://www.phplist.org/manual/books/phplist-manual/page/upgrading-a-manual-installation ) ?
At the moment users of older versions are directed to a dead link
I’ve changed the aforementioned link in the initial post. Sadly Anna is no longer with phpList.
Hi @Dragonrider thank you for the change but I was more concerned for those that read their older UPGRADE files in the old installation. I had tried to visit the old link as it was mentioned in the old files. If easy enough maybe add an http 301 at apache level on the phplist.org site
You could add a section mentioning other files that can be used to customize an installation, like
  • admin/defaultFrontendTexts.php
  • texts/language.inc
that will also be replaced using this method.
I did not find out, if those files would be left untouched using the automatic updater. I guessed not, which is why I prefer manual updates. It would be nice though, if their content would be moved to the database like other frontend options.
