I need a guide how to setup crontab the manual way. I know, that there help page, but this is very old and I can’t find the mentioned things in config or processque (it’s about 10 years old).
I don’t understand, if you have to put the in the commandline (putty with my host) a instruction or in config.php something.?
All guides made it worse, because they are all using different aproaches.
Here is my settings:
I have managed server and want to limit the mails to 150 per Hour with 1 second between the messages.
The cronjob should be executed every hour. In about a week, the newsletter is sent fully.
Now I tell you, what my managed server does support:
PHP 4.4.9 (cgi-fcgi)
Copyright © 1997-2008 The PHP Group
Zend Engine v1.3.0, Copyright © 1998-2004 Zend Technologies
Now I need to know, how can I configure cronjob like statet without using cPanel (which I’m not using anyway) or without signing to some cronjobing service including phplist.org too…
I need know, what kind of a file I have to create (or need to a create file??) and what kind of instuction I have write in putty to let the executable to execute and which software you recommendend like putty…or how you did it.
If you need more help, please tell me.
EDIT:
I found a now the official website for Cron Jobs, which is indeed new. Will take a look and then tell you, if I need help or not. Official Cron Job help page is: https://www.phplist.org/manual/ch036_setting-up-your-cron.xhtml
