I have successfully set up phplist on a shared host (transip) and everything seems to be working fine except for bounces.
I’ve created a test subscriber with an email address known to bounce (bouncetest@tribulant.com).
When I send a test campaign I do see it arriving at another test subscriber which I do have access to.
When I check the pop mailbox for bounces, I do not see any. When I email the above address for testing bounces directly I do get a bounce reply.
Below is my config file. Any suggestions for what I might try to fix this?
<?php
* The minimum requirements to get phpList working are in this file.
* If you are interested in tweaking more options, check out the config_extended.php file
* or visit http://resources.phplist.com/system/config
// what is your Mysql database server hostname
$database_host = 'localhost';
// what is the name of the database we are using
$database_name = 'mydomain_com_phplist';
// what user has access to this database
$database_user = 'mydomain_com_phplist';
// and what is the password to login to control the database
$database_password = 'mypassword';
//# if your SMTP server is called "smtp.mydomain.com" you enter this below like this:
//# define("PHPMAILERHOST",'smtp.mydomain.com');
define('PHPMAILERHOST', '');
// this is here, to make sure you edited the config file and mails are not sent "accidentally"
// on unmanaged systems
define('TEST', 0);
// if you change the path to the phpList system, make the change here as well
// path should be relative to the root directory of your webserver (document root)
// Warning: Do not change this after installation. You can only change this before you
// install and initialise phpList.
$pageroot = '';
* Settings for handling bounces
* This section is OPTIONAL, and not necessary to send out mailings, but it is highly recommended to correctly
* set up bounce processing. Without processing of bounces your system will end up sending large amounts of
* unnecessary messages, which overloads your own server, the receiving servers and internet traffic as a whole
// Message envelope.
// This is the address that most bounces will be delivered to
// Your should make this an address that no PERSON reads
// but a mailbox that phpList can empty every so often, to process the bounces
$message_envelope = 'listbounces@mydomain.com';
// This can be 'pop' or 'mbox'
$bounce_protocol = 'pop';
// commandline
$bounce_mailbox_host = 'pop3.transip.email';
$bounce_mailbox_user = 'listbounces@mydomain.com';
$bounce_mailbox_password = 'mypassword';
// the "port" is the remote port of the connection to retrieve the emails
// the default should be fine but if it doesn't work, you can try the second
// second line
// $bounce_mailbox_port = '110/pop3/notls';
// $bounce_mailbox_port = "110/pop3";
// it's getting more common to have secure connections, in which case you probably want to use
$bounce_mailbox_port = "995/pop3/ssl/novalidate-cert";
// when the protocol is mbox specify this one
// it needs to be a local file in mbox format, accessible to your webserver user
// $bounce_mailbox = '/var/mail/listbounces';
// testing things.
$bounce_mailbox_purge = 1;
// how many bounces in a row need to have occurred for a user to be marked unconfirmed
// choose the hash method for password
// check the extended config for more info
// in most cases, it is fine to leave this as it is
define('HASH_ALGO', 'sha256');
