View in Browser not working
I’ve tried just about everything I can think of, but I can’t the View in Browser plugin to work. I’m sure it’s me but I would like some guidance.
Here is the url that I get:
https://www.aandwh.co.uk/aawh_lst/?m=725&uid=1debf1e9-b570-42d5-a479-60c81ec685cb&p=view&pi=ViewBrowserPlugin&utm_source=phplist725&utm_medium=email&utm_content=HTML&utm_campaign=Try+a+New+Name
@talkpoppycock I guess that the plugin might not have been installed properly. How did you install it?
Check whether the file admin/plugins/ViewBrowserPlugin/view.php exists.
There is also a possible problem with the uid value.
It looks like you were affected by a bug in release 3.3.0 that overwrote the uid field with a
uuid value. The bug was fixed in release 3.3.1 but didn’t correct any incorrect values.
A uid value should be 32 hex digits, whereas a uuid is similar to the value that is in the URL you posted. As that probably happened a few years ago then you can probably leave things as they are.
Many thanks for your prompt reply.
My version numbers differ from yours, however this is what I did.
Plugin managers showed version 2.4.1 I disabled and then deleted the folder. I then installed the latest version which plugin manager said is 2.10.2 Then composed new campeign and this works perfecrly.
Many thanks for you help.
