Hi all:
Using the date plugin as follows:
Click Here for [TODAY:m/d/Y].
The first plugin fails (in the CLICK HERE link). The second one works. I am assuming that the first one is still in the quotes and causing the problem. Any way around this?
Hi all:
Nobody knows this one?
@square1 This might be caused by a bug in the plugin that stops more than one placeholder being used. If you remove the second placeholder then can you confirm that the URL contains the date correctly?
I have just submitted a fix for that problem to the plugin developer, see https://github.com/michield/phplist-plugin-dateplaceholder/pull/2
Also, how are you creating the campaign? It is possible that the [ and ] characters are being encoded as %5B and %5D. Can you view the source of your email to see whether that is the case?
With a single placeholder, yes, all is fine. I will look out for the update. Thank you!
The code is NOT appearing as %5B etc.
@square1 You should be able to update the plugin using my branch of the plugin. Just copy this into the package URL field on the Manage Plugins page
https://github.com/bramley/phplist-plugin-dateplaceholder/archive/multiple_placeholders.zip
You can then update again once a new version is released.
