I have just upgraded to phplist v3.2.1. Post upgrade, none my emails are been processed in the campaign queue. I have rescheduled the campaign few times and nothing happens to the queue.
Can someone please advise how to resolve this issue? We need to send urgent campaign by close of business Thursday.
Ok, well you can wait for help here (I have no idea by the way) But I would suggest that if your send is urgent you make some backup plan. You could send from www.phpList.com for $5.00, for example. Hopefully your issue will be fixed, but it’s not good to rely on free support for urgent mail I guess
a
x
@sriharign Can you provide some more information about what you have done and what is not working?
Which release of phplist did you upgrade from?
How are you processing the message queue - using the browser or a cron job?
If you use the browser then what is displayed by phplist when it processes the queue? If you use a cron job then check that it is still running and review its output.
Have you looked at the event log for any problems reported there?
