I updates through PHPlist (System > Update) and now i am stuck. Dashboard is giving only “phpList is in maintenance mode. Please try again in half an hour.” message.
maintenance value in database is zero (0).
Is the update still running or what is going on?
Problem solved.
Have to remove text “update process” from maintenance recond on config table.
Sorry but I did not understand how to upgraded the system more advanced …
I have run into the exact same “phpList is in maintenance mode. Please try again in half an hour.” message while trying to upgrade to the latest version of phpList.
I am a greenhorn to programming. I successfully loaded my phpMyAdmin through the control panel, however, I cannot find the config table you mention.
Where/How do I find the config table?
Thank you in advance for any help you may be able to provide!
