i installed the latest version 3.0.12 on my webserver (LAMP with php 5.4) and everything works fine. Instead of using the local mail-server on the machine, I want to use an external SMTP Server for sending mails. So I added the following lines to config.php
define(“PHPMAILERHOST”,‘mymailserver.de’);
$phpmailer_smtpuser = ‘info@mymailserver.de’;
$phpmailer_smtppassword = ‘mypass’;
define(‘PHPMAILERPORT’,25);
define(‘SMTP_TIMEOUT’,5);
But the system will still send the mails via the local mail(). What did I wrong?
Thanks!
