screenshots under
http://community.entheo-science.de/phplist/
sending of the newsletter stops after a short time.
What coud be the reason ?
how to put code with line breakes here in ?
I like to post my config file …
@joe_schraube If you are sending through the browser then you need to keep the window open. But it is more reliable to use a cron job. See the online documentation at http://phplist.org/
ok thanks - if I close the browser it stops sending … ? hm ok for what is this good for ?
I will read and learn …
https://www.phplist.org/manual/ch035_methods-of-sending-browser-cron-command-line.xhtml
