Send as web page
Since upgrading to phplist 3.2.4 the option to send as web page is not there. How do I get this option back or is there a work around.
Thank you
Send a webpage is still there as an option when sending a campaign in phpList 3.2.4
If you cannot see it, you may have some files missing or perhaps your PHP version is outdated? phpList 3.2.x requires a PHP version above 5.4
Thank you server crashed and had to reinstall apache will check on version of php.
Thank you
I have php 5.3.10 any php module that needs to be added. I’ve used this for about a year before apache crashed and it worked. Apache crashed the day I was upgrading so I was thinking it was php list.
Thank you for the input
Charles
@scdcardinal You probably need to enable the php curl extension.
Thank you adding php curl was the answer.
Thank you
