I have various attributes that I’ve added for entering additional info about each user.
I now want to search for certain subscribers using a key word in one of these attributes which is a ‘text area’ - but this particular attribute doesn’t show in the search page’s dropdown list of fields to search in?
From looking at which fields are avialable to search through in the dropdown, I suspect that the reason this field doesn’t show up is because it’s not a ‘text line’ (since the ‘text line’ fields are the only ones that show up) as opposed to a ‘text field’, ‘Select’ or ‘CheckboxGroup’ type attribute.
Is this correct - and if so, how can I search for a word in a ‘text field’ as opposed to a ‘text line’?
For instance would this scenario be possible . . . if I temporarily convert the attribute field to a ‘text line’ - then perform the search - and then change it back to a ‘text field’ . . . will I have corrupted (or changed) the data stored in that field for each subscriber?
Any help with the above would be most appreciated
Many thanks as always
Phil
