I have been using phpList with the Amazon SES plugin for approximately ten years.
I would like to send one campaign to my subscriber list while distributing the recipients approximately evenly across three different From addresses belonging to the same domain.
For example, if the campaign has 3,000 recipients, approximately 1,000 messages would be sent from each address.
All three addresses are authorised in Amazon SES. I want to continue using the existing Amazon SES API integration, not SMTP.
Ideally, I would like to select the three addresses when creating the campaign, and have phpList automatically assign a sender address to each recipient.
Is there an existing plugin or supported extension that provides this functionality? If not, is there a recommended way to implement it without modifying phpList core files or breaking the existing Amazon SES plugin?
I do not need advanced marketing automation. My aim is simply to reduce three separate campaigns to one.
