#### UPDATE ####
I would like to remove this question, because I found the cause of the problem. The Started/Finished message destination can be adjusted at STEP 5 of the Campaign Creation work flow. My colleague had changed it to something I did not expect, causing what I was puzzled over.
I used to get “Campaign Started” / “Campaign Finished” emails.
I believe the only relevant change I made was transitioning from the old style cronjob using lynx / curl / wget, to commandline method.
I still do receive the “phpList Maillist Processing info” email, but I do not get the STARTED / FINISHED emails.
In Admin pages > “Campaign Settings”, there are 2 relevant fields for the alert emails:
Default for 'email address to alert when sending finishes’
Default for ‘email address to alert when sending starts’
Both are correctly filled with my email address, and I didn’t touch them.
What do I need to do to re-enable those emails?
Thank you.
