is there a way to resend campains (not requeue) with a longer delay than 4 weeks?
I unlocked the option , but the max duration i can set is 4 weeks. I would need soemthing like 20-30 weeks
Thank You,
Radu.
Thank You,
Radu.
anyone? any ideea?
tx…
since no one helped, i searched through the files and found a way…
the setting is in the file “send_core.php” and is in minutes.
i edited “fortnight” - changed it to “half a year” and put 250 000 minutes. Its grossly 6 month.
Im sure there is a better way to do it, but my coding skills are very limited…
If that helpes anyone…
