Hi there!
We were using this cron job:
wget -q -O /dev/null http://www.domain.com/newsletter/admin/index.php?action=processqueue&secret=########### 1>/dev/null 2>/dev/null
And it was working great… until we started to see that it was not working anymore
In fact, if I go to http://www.domain.com/newsletter/admin/index.php?action=processqueue&secret=########### I just see a login page… is that the regular behavior??
Should I see some information about news being sent, etc instead that?
And then, I tried to login first… and after that go to the above URL,
And it showed something like the phplist admin menu? and at the end:
{“campaign”:0,“num_users_for_message”:0,“batch_count”:0,“batch_total”:0,“sendemail
returned false total”:0,“send blocked by domain throttle”:0,“add
attachment error”:0,“sendemail returned
false”:0,“sentastest”:0,“invalid”:0,“failed_sent”:0,“sent”:0,“num_per_batch”:-1,“delaysend”:599}
Is that ok? it looks like its showing some array sending stats (in this case saying it is in delay mode, waiting for a new output serie)
And that seems to work (I can see the amount of sent news increasing…)
So… why is that? to use the secret key url way do I have to always login first?? I thought that should work ok as anonymous, or not?
No idea what to do, or check… or what… D-:
UPDATE: my bad, it is not working… as the queue, for some known reason?, needs my login first… It is not working when it is launched by the cronjob, as that “browsing” is anonymous…
D-:
PD: what happend with the old forum? was deleted?
