when I use the [CONFIRMATIONURL] like in your new template message (continue receiving messages) for the GDPR update I got the following problem.
It leads to “https://engel-und-erde.de/lists/admin/http:/www.engel-und-erde.de/lists/?p=confirm&uid=xxxx” and not to “http:/www.engel-und-erde.de/lists/?p=confirm&uid=xxxx”
How can I fix this?
What are your path settings in the config file?
This one?
’# if you change the path to the phpList system, make the change here as well
’# path should be relative to the root directory of your webserver (document root)
$pageroot = ‘/lists’;
This is the link in the web config: http://www.engel-und-erde.de/lists/?p=confirm
The links in the footer are working, both of the message are leading to the wrong path
That’s the one. Okay, how about the ones in your admin page, configuration?
Website address.
Then further down the page, the paths in Subscriptoin Settings?
Are they showing the correct path?
Website address (without http://)
'www.engel-und-erde.de
subscription settings
The default subscribe page when there are multiple
1
URL where subscribers can sign up
http://www.engel-und-erde.de/lists/?p=subscribe
URL where subscribers can unsubscribe
http://www.engel-und-erde.de/lists/?p=unsubscribe
URL where unknown visitors can unsubscribe (do-not-send-list)
http://www.engel-und-erde.de/lists/?p=blacklist
URL where subscribers have to confirm their subscription
URL where subscribers can update their details
http://www.engel-und-erde.de/lists/?p=preferences
URL for forwarding messages
http://www.engel-und-erde.de/lists/?p=forward
