Hi There
I got very strange problem on Subscribers plugin
Here is my Hosting Environment
apache 2.2.3
msql 5.6.33-79.0
php 5.6.14
phplist 3.3.1
Subscribers Plugin 2.9.4+20170414
Common Plugin 3.6.1+20170414
I was using “admin” user on http://xxxx.xx/lists/admin/?page=details&pi=SubscribersPlugin&tk=02ec8c0d2e952f344c48e8a55c472fce
everything work very well, I forgot what I did on this page, now the problem is has error message said databases error
Database error 1064 while doing query You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Lamps)' at line 3
A problem with the query: SELECT name
FROM phplist_listattr_producttyp
WHERE id IN (Audio Lamps)
#0 /home/XxXxXxXx/public_html/lists/admin/plugins/Common/DB.php(79): phpList\plugin\Common\DB->_query('SELECT name\nFRO...')
#1 /home/XxXxXxXx/public_html/lists/admin/plugins/Common/DB.php(120): phpList\plugin\Common\DB->queryAll('SELECT name\nFRO...')
#2 /home/XxXxXxXx/public_html/lists/admin/plugins/SubscribersPlugin/DAO/User.php(303): phpList\plugin\Common\DB->queryColumn('SELECT name\nFRO...', 'name')
#3 /home/XxXxXxXx/public_html/lists/admin/plugins/SubscribersPlugin/CbgConverter.php(51): phpList\plugin\SubscribersPlugin\DAO\User->cbgNames(Array, 'Audio Lamps')
#4 /home/XxXxXxXx/public_html/lists/admin/plugins/SubscribersPlugin/Controller/Details.php(153): phpList\plugin\SubscribersPlugin\CbgConverter->current()
#5 /home/XxXxXxXx/public_html/lists/admin/plugins/Common/Listing.php(52): phpList\plugin\SubscribersPlugin\Controller\Details->populate(Object(phpList\plugin\Common\WebblerListing), 0, 50)
#6 /home/XxXxXxXx/public_html/lists/admin/plugins/SubscribersPlugin/Controller/Details.php(72): phpList\plugin\Common\Listing->display()
#7 /home/XxXxXxXx/public_html/lists/admin/plugins/Common/Controller.php(110): phpList\plugin\SubscribersPlugin\Controller\Details->actionDefault()
#8 /home/XxXxXxXx/public_html/lists/admin/plugins/Common/Main.php(43): phpList\plugin\Common\Controller->run(NULL)
#9 /home/XxXxXxXx/public_html/lists/admin/plugins/SubscribersPlugin/details.php(37): phpList\plugin\Common\Main::run(Object(phpList\plugin\SubscribersPlugin\ControllerFactory))
#10 /home/XxXxXxXx/public_html/lists/admin/index.php(712): include('/home/XxXxXxXx/pu...')
#11 {main}
I thought it was a database problem, but when I tried other user, everything work very well again. so I login out and use “admin” user , same error message again.
Please help me.
best regrads
Leslie
