Hy,
I faced a recurent problem with phplist, the impossibility to upload images.
The path roots is set /lists, the UPLOADIMAGES_DIR is set too lists/sandpit and i have let the File system path to the upload image directory empty as preconized.
Conclusion no image upload and when i load the template he want to look for the pictures inside http://192.168.1.21/lists/admin/plugins/fckphplist/fckeditor/editor/picture.jpg
By the way phplist go to look in the good folder when you send a campaign with embeded image previously manually drop in the good folder.
And subsidiary question. Someone succed to run phplist on a synology? Same problem a little more tricky. Upload folder don’t want to be accessible at all even when i change inside the syno the open_basedir for having this form /tmp:/var/services/tmp:/var/services/web:/var/services/homes and not something like /volume1/… and of course the folder writable. The NAS seem not to be aware of any configuration gave to pplist to reach the folder and no possibility to send campaign with enbeded image.
If someone have the solution.
