When I start the queue to send 500 emails I get an info via email that 30 mails were send. then stops the queue
what I have to change in the config.php?
who can help me?
here part of my config.php
define("MAILQUEUE_BATCH_SIZE",200);
define("MAILQUEUE_BATCH_PERIOD",1800);
# (or you can play with the autothrottle below)
define('MAILQUEUE_THROTTLE',2.0);
