@duncanc I really really need to learn to properly read through my code. I was simply missing a " from one of the div’s.
All seems to be working well now, as far as I can tell.
Bravo & thank you.
Bravo & thank you.
If you have Dreamweaver, it’s good at showing you the code, and color codes the html for you.
Another option might be ‘brackets’ which is open source.
