Hello to all
how many limits can be set in an a PHPlist’s installation ?
I understood that i can set X messages per hour…
But would be possible to set something like :
X messages for Hour
AND
X messages fo Month
can i have a countdown of remaining email?
Thank you all
The x messages per hour is to avoid getting marked as a spammer and to avoid getting blocked by your host. Not sure why you would also want to set a monthly limit? There is a countdown of how many left to send in the Active tab of your campaigns list.
Phplist Team, in his Hosting specify : “the trial account is limited in volume:
It allows you to send up to 300 messages per month with a daily limit of 50 messages.”
How can i apply this limit?
i make it with “MAILQUEUE_BATCH_SIZE” and “MAILQUEUE_BATCH_PERIOD” or in other way?
Hi, I think I spoke to you by email earlier. The trial account you refer to is on phpList.com. With phpList.org you do not have any limits, other than the technical limits of your hosting.
