Hi, I’ve been greeted with this error eversince installation. Even though the pageroot has been set correctly in both the config.php and init.php.
The pageroot in your config does not match the current location
Check your config file.
My other problem is the url keeps adding the letter “s” right after my $pageroot. i.e. list becomes lists. I can’t for the life of me figure out what is causing this.
@AlifOpenSrc You are changing the wrong file, see the beginning of config.php
There is no need to make other changes to the phplist source code.
